Which metering mode do you use most?
  • Reflective
    Votes: 31 41.9%
  • Incident
    Votes: 31 41.9%
  • Spot
    Votes: 12 16.2%
  • Total voters
    74
Bosk
Make photos, not war.
5:42 AM
Greetings photogs!
After many months of absence from these boards I've returned, having renewed my interest in rangefinder photography after a well-needed break from poking my Leica in the faces of strangers.:eek:
Given that I'm planning on purchasing a handheld digital lightmeter of some sort by the end of the month (I'm leaning towards one of the entry-level Sekonics) I thought it might be interesting to post a topic discussing which metering mode you prefer to use most often when out in the field, and why.
Please feel free to vote in the poll, and if you wish to also let us know why you tend to favor the metering mode you do, or why you use a combination of modes if that's your thing.
Apologies if similar threads have been posted but I've been unable to find any.
Cheers, Bosk.
Although I think incident is best, I tend to favour reflective metering, as I have lost the bit of white glass from my Leningrad 8 :(
Persons with such a bit are invited to pm :)
Cheers, Ian
Reflective, from a middle grey object. Set the camera to the aperture/shutter combination (which appears to be 1/125 at f8 all the time)..
reflective ... using either the build-in meter (Leica MP) or hand-held (Gossen Digisix) with the M3
Incident from a basic Sekonic 308 all the time.
It's simple. Meter light, meter shadow, forget it til the conditions change. When I used TTL I felt obligated to fine tune the metering every time I brought the camera to my eye. It really affected how I concentrated on what I was shooting because I was so preoccupied. I heart incident :D
Inbuilt spot + a bit of judgement. I've trained myself to avoid re-metering for every shot unless the light is very changeable.
Ian
For me it's what's at hand. If using my SLRs or any other camera with a trusted meter, it will be reflective almost exclusively. With a meterless cameras, it used to be incident almost exclusively since I had a Sekonic incident meter with a large dome. Now that the Sekonic got dropped one to many times, I moved to a Gossen Luna Pro and Luna Pro SBC. Probably use reflective more than I used to. I just don't get as warm a fuzzy with the small incident domes on those meters.
When I carry my Sekonic L-308 I prefer incident metering. When I pop on my CV I meter, it's reflective. If I forget to bring a meter it's sunny-16 with some adjustments for breezes :)
Incident for medium format. With my bessa I just point at grass or grayish tarmac and meter off that with a bit of sunny 16 thrown in.
This is basically what I do but use the ttl instead of a hand held meter. It's amazing how many times I'll put the camera up to my eye and it's already properly set.
I find myself mainly using reflected metering but am trying to use incident more..
As usual, it depends. I voted incident, but I use all three, including one other method not mentioned: sunny 16 (which is really incident).
Combination of Sunny 16, guesstimate and whatever is written on the inside of a box of Neopan 1600 for low light.
Works surprisingly well.
I mainly use a spotmeter. Even when using an averaging meter, I point the lens to a small area and then adjust in my mind the overall exposure. When the weather is perfect, I use the Sunny 16 or Sunny 11 rule depending on the time of the day and the location. In Europe, I use the Sunny 11 rule, whereas in Florida I use the Sunny 16 rule.
Raid
Incident is the most reliable, but sometimes distance makes reflected the only option. An "incident" reading can be had by taking a reading off the palm of a hand with a TTL meter -- if the light on the palm is the same as that on the subject -- and opening up one stop.
