Which "Rodinal"?
Steve M.
3:40 AM
I want to shoot some Tri-X and develop it in Rodinal, but I forgot which one is the "good" Rodinal. My experience 15 years ago was w/ the R08 variant and it worked great but went off in just a few months. Not exactly what I had expected.
Only ADOX Rodinal is made of the original, latest Agfa Rodinal formula by Agfa in Germany.
All other clones are slightly different.
Ah, that simplifies it. I'll order some from Freestyle now. Thanks guys.
On the other hand, this makes the case that R09 and Adox Rodinal are identical. I guess the R09 is the new version or the R08 that I used years ago:
https://whystoptime.wordpress.com/2016/02/23/compare-r09-to-adox-rodinal/
The article is wrong. R09 is not the same. Similar, but not the same.
And R09 is not made by compard. It is only bottled by compard. Compard is not a chemical manufacturer, they are a finishing / bottling company.
And I have never heard of an R08 version.
Calbe R09 is no longer available
The resulting negative using the pre-war R09 formulation will be very similar at higher dilutions.
Calbe R09/APH09 had a slightly lower pH value versus the modern Agfa Gevaert version of Rodinal post 1964. Both concentrates are very alkaline, but they are not exactly the same.
None of this matters, because blue label APH09 has been discontinued.
Below is an older discussion on APUG / Photrio:
Difference between R09 and Rodinal
Section 9 of the MSDS for the Calbe R09/APH09 shows the concentrate has a pH of 11.8:
https://www.digitaltruth.com/products/adox_msds/Adox-APH-09_MSDS_EN.pdf
MSDS for Adox Rodinal shows the concentrate to have a pH value of 14, see section 9:
https://www.digitaltruth.com/products/adox_msds/Agfa_Rodinal_MSDS.pdf
I would assume that the Adox Rodinal would be more active w/ a higher PH? Believe me, I'm no chemist, so a visit to the old APUG site would only give me way more information than I want or need. The old R08 I had worked great at 1:25 w/ Tri-X. Lots of beautiful grain, it just didn't last long for some reason. I'll go w/ the Adox and see how long it lasts.
Meanwhile there are stories of people using Agfa Rodinal that's been sitting around for years and it's fine. I've developed film in Rodinal diluted from 20 year old concentrate and the results were more or less indistinguishable. The Adox certainly seems to be the same stuff, and anyway I'm pretty comfortable with it and it's longevity (though I may periodically test it as well all get older before I use it on precious film).
I've only used R09 a few times, and not in years, but my memory is that it was a little different, but not much. The reports of its shorter lifespan are worth noting. I'd use it if a client requested it, but otherwise I'll stick with the Adox.
This is as much about the bottle as the developer. Various Rodinal formulae are good at resisting oxidation, but bottles that allow free movement of oxygen facilitate oxidation and developer failure.
Marty
Marty
That's the big problem. Rodinal used to come in little brown glass bottles. By the time I learned to develop film in High School around 1991, they were using plastic. I bought a bunch of small brown glass chemical bottles, which I use to store my Rodinal.
I didn't want to go to far into all the details in my post above, but probably its necessary:
1. There was the former pre-war Rodinal R09 formulation. That had been produced by Calbe in Germany quite a long time (and also offered by ADOX APH09), but it is indeed discontinued now.
2. There is the "R09 One Shot" bottled by compard. That is neither the pre-war R09, nor the latest original Agfa formula. It is a clone made by Tetenal. Similar to Rodinal, but not identical.
3. There is Tetenal Paranol S as Rodinal clone. Similar, but not completely identical to Rodinal.
4. There is ADOX Rodinal and ADONAL. That is the original Agfa formula which was used by Agfa before they stopped production. ADOX has bought the formula and the rights/name.
ADOX is using high quality bottles with an inner coating, which reduces oxygene diffusion very significantly and improves shelf life.
Having used the R09 One Shot for the last ten years or so, would I see any difference in switching to the ADOX Rodinal? I use both 1:25 and 1:50 dilutions. The image in that link above would lead me to believe I would not.
I directly asked Mirko but said he was unable to comment on the R09.
I used ADONAL with good results and good stability for a while.
Do be careful: All these are caustic enough to give a wicked burn; a splash into the eye could be catastrophic.
The short answer is no. All para-aminophenol developers with an hydroxide alkali and a little sulphite (added as metabisulphite, but all the hydroxide alkalinity turns it into sulphite) produce negatives that essentially look the same.
There was a guy who used to (and may still) preach on the internet that 'real' Rodinal was made with lithium hydroxide as the alkali, which he claimed was nearly impossible to obtain, but, if used, would magically turn make a Rodinal that would be a silver development bullet. Lithium hydroxide is not hard to get, nor is it a magic bullet. At the same pH it doesn't really matter much what cation accompanies your hydroxide.
I am pretty sure with Adox product you don't need to decant into other bottles or worry about batch variation. Fortunately.
Marty
Currently, I use Agfa Rodinal.
Bought from eBay DE, 2 years ago, produced 1973 still works until today.
My Rodinal stock
ADOX Rodinal also good choices.
