Why I can't stop using Tri-X
7:36 AM
The stuff is just amazing. It makes even the most banal vacation photos fascinating to look at. These were from my week at the Jersey Shore...just got back, souped the stuff in Rodinal 1:25 for 7 minutes, scanned, fiddled a bit in Lightroom.
This is my first try with Rodinal. It gives you a really different result from D76--I'm quite surprised at that. The grain is more prominent, and the pictures have a certain character.
All shot with the Bessa R4A and 50/2 Heliar Classic.
That Rodinal has a lot of character ... I've just started using it with HP5 which I hadn't used for a while and had previously developed it with D76. The Rodinal gives the Ilford more prominent grain similar to what I see in your pics ... it's a unique developer and takes a little getting used to but definitely gives results with bite! :p
trix and rodinal, a lovely couple I also use :)
I really like it
for outside picture I prefer 1+50 13 minutes, that give fantastics sky if there is clouds :)
I figure if it works, why fight it? Tri-X is a great film and incredibly versatile. I prefer it in HC-110 dilution G. I get results I like just as much out of Neopan 400, but it's not the same thing. Tri-X has a definite character.
I like very much pulled TriX in Rodinal esp. for the brilliant (but not washed out) whites (lol sounds like an ad for a detergent). I don't use often the film that way but whenever I did it was a treat. It's with standard pushing that I 've always had problems with (mushy shadows in a variety of speed enhancing developers), so much so that I prefer HP5+ and Neopan 1600 for their nominal speeds and beyond. Rodinal in higher dilutions gives a moderate compensating effect with good acutance and you may circumvent the speed penalty with stand development. I 've seen some truly beautiful photos (sadly not mine) with this treatment.
Interesting. I haven't tried pushing either for a very long time. All I used was D-76 (all I had at the time). But my recollection was that Tri-X pushed better. HP5 was better drying. You just couldn't get water spots.
After a few years of digital I got sorta bored. I did a lot of concert shooting back then and the transition from film to digital was very welcome. Not that film couldn't cut it, but processing, scanning and postprocessing, man, that ate up a lot of time. But digital got kinda boring and repetitive after a while.
I never managed to get the 'look' of earlier B/W concert work myself. So I bought a Nikon FM for fun and started shooting some B/W, but the lab was't very consistent in developing my film. So I ended up in forums like this one and learned about developing yourself. I made the jump and started with Diafine and Tri-X.
What I got was this, actually from my very first roll
Wildest dreams and all that
Silly question : is 400Tri-X same to 400TX?
Not a silly question; when manufacturers "reformulate" or change the name of a film emulsion, things can get quite confusing. When originally looking for this answer myself, I had trouble finding anything definitive. There have been some changes in developing times from the older emulsion (which I think used to be marked "5063" on the film edge), and perhaps a finer grain structure. Some say that the grain, which makes this emulsion what it is, in my opinion, is now less "gritty".
This thread on RFF tries to answer this question, too.
Bottom line is, aside from some different suggested development times, my understanding is that very little has changed (for the worse, at least). That's probably why folks that use 400TX still call it, "Tri-X". It's my understanding that there's a greater difference between the 135-size 400TX and the 120-size 320TXP (both "Tri-X") than there is between "old" and "new".
Hope that's not too obfuscating.
--joe.
--joe.
Thanks, Joe
I really thought Tri-X is still being sold everywhere except here :)
...a bit more nuances in the greys
Thanks, vrai; I've noticed that this fact is especially appropriate for its exclusive use as a medium-format emulsion - the results I've gotten from normally-exposed 320TXP are really fantastic.
My next step is to home-develop this film, which I've yet to do. Perhaps some dilute HC110 (dil H, for instance) would do nicely.
--joe.
Ummm I hate to tip my hand but I'm going to because I want to be sure there is a continued buying public creating demand for these films
I like Trix / 400 ISO and I dev it in HC110 : it's outstanding
I prefer TXP / 320 ISO and dev it in HC110 : its unbelieveable for fast BW
I love Acros / 100 ISO and dev it in Rodinal: it's probably the best BW ever
One caveat, all this is based on 120 film
Here's the Tri X / 400 in HC110 This is a '30%' low res version for the web....
Here's one of my results of Tri-X (@rated speed 400) in Rodinal 1:50, 13 minutes. Scanned on Epson V500 without grain-reducing feature. Leica M4, Jupiter-8:
