Wide open please ...
Matus
1:59 AM
Hello I am just about to jump on either Bronica RF645, Mamiya 6 (6MF) or Mamiya 7 (7II) and I would love to see some wide open shots made at closer distance that show a bit of character of the lenses (portraits, architecture, etc.) through out the whole range of focal lengths.
So, would you be so kind to share a few ... :)
Mamiya 7II, 80/4 all wide open, just remember f4 is still f4, if you want closer focusing and shallower DOF you might consider an SLR.
Todd
thank you - some really nice photos. Yes I do realize that MF RF cameras are not the first choice for shallow DOF (Contax 645 + 80/2 is probably hard to beat for portraits), but your samples clearly show that subject can still be nicely separated form the background especially for close focusing distances.
Of course I would gladly see more :)
Here are some shot with the Bronica RF645 and Zenzanon 65mm f4.
All shot on Neopan 400, last one pushed to 1600.
edit - last one might actually be the 45 at f4.0 because I can't imagine having had the distance to get that all in (I should start taking better notes)..
RF645 with 65mm at f5,6 using Kodak E200 at ISO 200
RF645 with 65mm closest focus and f4.0 on Kodak E100VS
RF645 with 65mm at f5,6 on Kodak E100VS
I often use f4,0 setting on the lens, but usually it is night images and not very close focus. If you want to do macro and headshots, then I would suggest the excellent Contax 645 with the 80mm f2,0 lens. If you want a compact and relatively light medium format camera for a variety of image choices, then I would highly recommend the Bronica RF645.
