Wide to short tele zoom lens in M42/Praktica/Pentax mount?
POSTI-Tuomo
Level 1 Camera Repairman
8:27 PM
I'm in search for a decent zoom lens for my Fujica SLR, do you know any good choices? It mustn't be a brilliant performer, just decent so that it works. I detest the idea of having to carry multiple fixed focal length lenses with me wherever I may roam... I recently bid on a Pentacon 39-80mm f3.5 lens, but the price went a bit too high for me. So no luck there... I am skimming through the various electronic Bay stores, but haven't found any suitable lenses so far.
I would recommend a Tamron Adaptall 2 lens with an M42 removable mount,either the 35/80 SP model,or the 28/80 SP.I have used both and they are excellent.If you change camera marque at any time,just buy the appropriate mount and the lens can move to the other camera.
BTW --SP stands for 'Super Performance.'
Brian.
Fitting a K-mount lens to the Fujica?
Is there an adapter made for K-mount lenses to fit M42 bodies? I found a decent lens on the auction site, but it is in K-mount... Didn't find any adapters when I searched for them, but I think they exist. Sure enough, plenty of adapters for Pentax K-mount bodies but not the other way around...
Lens register wouldn't be a complicating factor, as both mounts have 45.5mm lens-to-focal-plane distance...
About the Tamron Adaptalls: they seem to be popular zoom lenses, no wonder though. The mounting system makes them very versatile lenses. And I've heard the image quality isn't that bad either....
Posti - the Adaptall lenses, especially the SP range, are good performers and have good close focus ability for such zooms. There is no K lens to M42 camera adaptor - the K mount is wider than the M42 mount.
Look for "Sakar" brand zooms on eBay. It has a 28-80mm zoom which sometimes appears in M42 fits. They're not pricey too. Or do a search under the categories "M42" or "Pentax" or "Screw mount". Many inexpensive 'housebrands' (lenses rebadged under the names of the stores which they were sold in like "Focal" or "Sears") zooms made in the 1970s-80s
could be found as well. The most common M42 zoom range found though are in the 70-200 mm range. I was able to get a 24-35 M42 lens once for just $20
on eBay.
Jay
on eBay.
Jay
Good tips, Jay. Zoom lenses from the 28-80mm range can be found on eBay, too bad they usually come in different mounts, and all of them are wrong... :D Maybe different wording in the search function would yield better results.
Yes, the 70-200mm range seems to be more prevalent. But that's not really what I'm after, 2 reasons for that: I've got a half-functioning 28mm lens (the diaphragm sticks, will have to try repairing it) and a 200mm tele as well. And anyway, a 70-200mm lens would be too bulky.
Sigma 24mm-70mm F3.5-5.6 Aspherical
I bought this lens in Canon FD mount in the early 90s. It was the only lens I used on 3 trips to the Canadian Rockies. Heck, it was the only lens I used for about 10 years. It uses 55mm filters like my other Canon lenses. It's a keeper lens for sure.
Hmm, does that come in M42 mount as well?
Lots of mounts
Lots of mounts
Sigma made versions in all popular mounts back in the 1980s when the lens was first introduced. My guess: Yes.
M42 zooms are few and far btwn. By the time they figured out how to make short zooms affordably and well, everyone was into K-mounts.
Your best bet is to stick with a Tamron Adaptall2 zoom. Even the basic 28-70 is not bad, but the SP series is much better.
I've had a few Sakar & Focals etc, and haven't been impressed by the quality, so unless you get one cheap or free, you're better off looking elsewhere.
Thinking back,I have also used the 35/70 Chris has detailed(I had a thing about Tamron zooms in my ship photography days).
I found that the 35/70 is virtually as sharp as the two SP lenses I mentioned earlier,it is MUCH MORE compact,and has the great virtue of being a lot cheaper because it does not have the SP badge.:)
Brian.
Brian, you do not happen to have that lens just lying around, waiting to be picked up by loving hands for a reasonable price, do you? :angel:
Unfortunately not,the only one that I held on to is a 70/150.I always used them on M42 bodies,and never had on problem with them.
The very best Tamron that I ever used was the 35/135 4.2,which was outstanding.More bulky than the others mentioned,but perfect for shooting from the Dockside.
Happy days.
Brian.
I would recommend the Vivitar Series 1 zooms. They have excellent zooms in the 70-210mm range. In the range you mention, one particularly good zoom is the 35-85mm f/2.8, if you don't mind the size and weight.
