Will a Nikon SB-20 do TTL properly on a Contax G1?
Jerry Thirsty
7:57 AM
Hi all, I'm looking for alternatives to my TLA 200 flash. I also happen to have a Nikon SB-20, which looks like it might work. So long as I set it to TTL the flash symbol lights up in the viewfinder and it sets the shutter speed to 1/60th. I intend to run a roll to see how it works, but if anyone has any experience or tips to share I'd like to hear them. thanks, Jerry
Interested to hear how this works out. I have a G2 and an SB-25, but have never used the two together. I'm going to guess "no," but there are occasionally pleasant surprises. I agree that the TLA200 leaves much to be desired. While it does TTL and the distance is very easy to set, you can't bounce it. Head-on flash is rarely a good look.
Short answer: no. The contacts are in the the same postitions, but that's where compatibility ends. The electronics are different. It will indeed work fine in full manual and Auto (aperture/thyristor) mode; but TTL won't work correctly.
Okay, well I figured it was worth looking into. I'm comfortable using it in A and M, but TTL would have been nice too. I found the hot shoe pinout for Nikon, but not Contax: does anyone know the pin assignments, or have a diagram?
