Canon LTM Will Canon 7's Mount Fit Canon P?
jyl
Just learning to focus
12:16 AM
As the subject says . . . the mount screws look like the same number and location, would it work?
Yes it will John. I'm surprised that Joe hasn't responded as he has both cameras. They are both Leica thread mount. (LTM)
frank, i think john is talking about the actual mount. taking the mount off one camera and putting it on the other.
not about that they are both screw mounts.
this is more in brian's territory as i'm not very technical at all.
joe
Yes, I saw this post and just checked my Canon 7 against my L1, very similar to the Canon P.
I think this will work. The breech mount is offset from the body; the screw holes are in the same position, and the bodies themselves look the same. I have even seen a Canon 7 breech mount on a Russian Leica copy, see Cameraquest.com for that one!
I had the mount off of (now) Joe's Canon 7; it uses a shim underneath the mount for the proper lens-to-film spacing. I bet it is the same as the Canon P.
However if you're planning on swapping it for using the 0.95 lens, I've read that the massive barrel will cover a big section of the 50 finder area on the P...
Now another mad idea I had some time ago was to take advantadge of the extra thickness of the Canon 7 lens mount and 'swap' it for a M mount one, giving access to all the screw and m mount lenses on a Canon RF...
Yes, I was actually musing about the 0.95 - but it looks like it might cover the rangefinder window in addition to obstructing the viewfinder window.
I just held the 50mm f0.95 up to the L1; it covers the RF window so you are out of luck.
However: unless you have a completely dead/beyond repair Canon 7 with a donor mount, why not just get a Canon 7? They are cheap compared to the price of the 50mm F0.95 lens and have light baffles built in to match the F0.95. I had my jammed Canon 7 repaired at Essex and fixed the one Joe has now using a repair manual downloaded free from the web.
Makes sense, Brian. I am just feeling guilty about having too many cameras. More bodies than lenses suggests my priorities are twisted.
"More bodies than lenses suggests my priorities are twisted."
Are you sure you're posting to the right forum?
Consider - I currently have two cameras that I've never processed film from, two cameras that I haven't shot with in 3+ years, two or three cameras that I can't even locate, two cameras that are broken . . . and I'm researching the next camera purchase as we speak. I mean, if I were a collector this would be normal, but I'm not. My cameras aren't rare, some of them are not even in particularly good shape ("heavy users"), none are particularly valuable. It is kind of embarassing.
My New year's resolution: I'm going to stop buying cameras (as soon as I get that Nikon F4) and buy only lenses, for at least the first quarter of the year.
Yeah, it's a wimpy resolution, but I don't want to overdo it. After all, I'm not in training.
Hi John, hope you never need to buy a camera to get (or even shot with) a desired lens ;-)
sometimes it's cheaper to buy a camera with it...
Re: Canon-7 mount at P: yes indeed the 0.95/50 will shadow the rangefinder window. Plus exchanging RF mounts needs measuring the film distance before and after the invasion.
regards, Frank
Yes, when I changed the shims on my Nikon S2 to use it with the 50mm f1.5 Sonnar I set it up on an optics bench. Doesn't everyone have an optics bench in their computer lab? I used a 15x loupe to focus a target at a measured distance. I changed the shims until the image was in focus with the lens set at the proper distance. The last step was to calibrate the rangefinder to agree with the pre-set/measured distance. With the 50mm F0.95, you have to be very accurate.
..forsooth! I bet most arguing about missing sharpness of a 0.95/50 comes from bad calibration and/or eyesight. I have no plaints!
