ywenz
http://cgi.ebay.com/LEICA-M2-M3-M4-...ryZ30030QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'm not sure why the seller only mentions M2 M3 and M4, but I assume this screw mount adapter will also bring up the 50mm lines on the M6?
FrankS
Registered User
I believe it will. It was likely manufactured in the same time period that the M4 was the current M camera, so it is marked: for M2,3,4.
richard_l
The blurb now sez: "This is a Leitz adapter that will allow you to use a 50mm screw mount lens on any Leica M series bayonet rangefinder camera."
ywenz
richard_l said:The blurb now sez: "This is a Leitz adapter that will allow you to use a 50mm screw mount lens on any Leica M series bayonet rangefinder camera."
It's totally reasonable to think it might just be a copy & paste job by the ebayer.. wasn't sure why he only mentioned M2, 3, and 4. However, I think it's safe to assume it will work with an M6.
peter_n
Its actually marked just M2 and M3, the same as one I've got here. Mine works on an M6TTL and an M7 and I'm sure this one will too. Good price so far...
gustav[] pEña
gustav[] pEña
I got one and i use it with my M4P. I guess its only says m2 m3 m4 couse the m6/mp just didn't exist.
