X-Pan in contrast with M6
macmac
11:26 PM
I am an M6 user with the Summicron-M 1:2/35 ASPH and the Summilux-M 1:1.4/50. I read the review of the X-Pan on the Luminous Landscape web site and, frankly, am suffering an extreme case of lust. I can see the obvious advantages to the Panaramic format for landscapes -- even accepting the developing and scanning issues -- but I'm interested in your opinions as to how well the X-Pan compares in 35mm format to my Leica kit. I would appreciate your views.
Big usggestion, rent one and take it for a spin. You will quickly know if it is for you.
It will be bigger, useable with only a lot more light, and capable of stunning photos. Oh, and noisy. But a lot of fun.
The lenses might be slow compared to Leica. But they can be used full open without problems, their quality and sharpness still surprises me :)
xpan vs m
xpan vs m
I bought an xpan before the m7 came out thinking i could use it for autoexposure. It never replaced my m's. that being said, it takes SPECTACULAR panoramics. the 45mm lens is fantastic and with velvia it really is special. the xpan compliments my mp but i rarely, if ever, really, use them for the same thing. you can use the xpan in 35mm very easily but that's not really the point of the camera, i think. if you're out and about and know you need the occassional panoramic, and don't mind having a slow 50 (f4) for your 35mm needs, then the camera is great. But I myself only take it with me when I know i'll want panos. And it's worth it.
if you want panoramics and can afford it, the xpan will not let you down.
cheers,
craig
Take a look at the Xpan gallery on this site and get a good idea of wht its used for. I had one with the 30mm and found that lens to be one of the best I have ever shot with. It was slow but for landscape it worked magic. If I bought another Xpan it would definetly include the 30.
I love Leica's, but with the Xpan you will enter into a new world.
P.S.
My bank account has strong arguments against th purchase of the Xpan 30mm lens.
Wim
macmac,
I have both the TX-1/30mm and the MP/35 summicron asph. The M is irreplacable. When I know i can definitely get good sunlight I will take the TX-1 for a spin! with the 30mm +center filter you really need good sunlight if you are hand helding it (which is what i usually do....)
having said this, the TX-1 always gives you those kind of "Arrhh" pictures because of its stunning perspective and excellent optics. I think the shuttle is very smooth and it is a joy to shoot with.
To me, the TX-1 compliments my MP as I usually carry my MP around
I have an XPAN I, 45mm, and 90mm lenses.
I have some of the sharpest, and most dramatic shots with this interesting camera. Two caveats however.
1) The meter is center weighted only. There is the usual limitation - it tends to overexpose easily. So bracket.
2) The paint on the body is delicate. It flakes off easily.
Other than that the system is great. I have looked many times at the 30mm lens. The sharpness is supposed ti be exceptional. BUT SO IS THE $$$$$. Also, it requires a center filter which reduces the f stop (to even out the vignetting effects of this lens). This would make the hand holding use more difficult.
Martin
One weekend with the XPan and you'll most likely be addicted ;)
I use one alongside a Leica m7, and I thoroughly enjoy both of them... I mostly use the
XPan on a tripod, but there are times when the panoramic format is just too compelling
to pass up :)
Now it's just a matter of practice (for me, that is -- I'm still pretty new at this).
But I'll be posting some panos from Odessa soon, hopefully -- depends on time and
how long the critter animation I'm working on takes :)
I'm considering an Xpan too (or a TX-2 to be exact). But I'm concerned about the slow lenses. I fear I'll be tied to a tripod. Is that an issue?
Also, should I consider something cheaper, like a Horizon S3 Pro?
I use the xpan hand held regularly. If you shoot in daylight...no problem. The first version of the xpan is pretty reasonable on the used market, but the xpan II is a better choice if you want exposure info in the viewfinder. I have gotten used to the I and it has never really been an issue for me.
I don't find it to be, I'm able to shoot quite nicely with it handheld during the day, but I also find
that it tends to stay in my bag until the sun goes down (except on the rare occasions when I'm
up early enough for sunrise ;)), at which point the tripod is necessary anyway :)
Martin
Have you tried any full length portaits or formals using the pano mode, with the 90? I have been really wanting to see some... I have seen a total of one. It is one reason I still keep an eye on Xpan threads. If they look as good as I think they should... I may still get one. Rented one for several weeks once. No 90 was availible.
I have a an Xpan with a 45mm and m6 and have discovered that when I take the pan out I almost always take my leica IIc as well since it's so small and has a completely different 'look'.
There are days when the light is changing too rapidly or I don't see in pan format and the 45 f4 shows it's limitations.
The Xpan reminds me of a contax G2 in that it's extremely sharp and has a similar body style and weight. It differs by being very quiet, almost silent like an M, and with a nice viewfinder.
Careful, however, because once you try it it's very hard to pass up!
been borrowing an xpan the last few days from a friend for a possible purchase....i usually shoot with an m2 and m4p...here are my impressions of the xpan compared to the leicas
it's bigger....not huge, but enough to make you take notice
not as quiet...playing with it without film the shutter sounded pretty quiet, but put some film in there and there's a definite whirring sound as the motor pulls that length of film across the gate...not too bad, but i could never tell when the shutter went off during all the sounds
slow lenses...i thought that f4 wouldn't be too bad, but during these winter months it seems like i'm needing faster glass or film...i shoot people and all handheld, so a tripod is no real remedy
cool FOV....although i've learned that it is definitely a panaromic camera and not a superwide with the 45mm....it's sorta like putting two 50mm together...it's wide, but it's still pretty corrected..no funky perspective with the 45...it's NOT like shooting with a 24mm...you get the depth of field of a 45 and the foreground background relationship of a 45, it just happens to be longer
it's fun to shoot...though i'm burning through more film faster now...i tend to take a few shots to adjust composition and i find that i'm hitting the end of the roll quickly (20 shots as oppose to 36)....
overall it's a great camera...a leica replacement? no...but definitely a good compliment
So what if the Xpan lenses are a bit slower than Leicas? Using a tripod (or at least a monopod) is not a big deal and really should be used with Leica glass also, in order to take full advantage of the sharp optics. You pay a lot for all these lenses, so why not take the extra step and get the best possible images from them? (Unless, of course, you are doing something like PJ or Street or have a bad back or just don't give a $#!^.)
I have on occasion gotten really sharp shots without a support, but I attribute it 99% to luck, and 1% to not tanking up on coffee.
OK I haven't an M6 to compare:
However I shoot mostly with a Bessa R2/R2a and 35mm f1.7 or 28mm f1.9 with velvia 100.
When I go out "on the hoof" with my xpan [as opposed to a specific shot with a tripod etc] I either push velvia 2 stops to 400 or use Provia 400, hey presto I can pretend my f4 lenses are now f2 [if you see what I mean] so shoot just like the standard 35mm set up!
The lenses are superb wide open......................
If you're shooting B/W with tri x or xp2 can see even less of a problem? ;)
Makes sense to me!
