X-Pan Set
chris000
Landscaper
5:25 AM
Following a couple of recent threads on X-Pan photos I was inspired to start a gallery on my website showing a few of my own - link in my sig. below. here are 3 examples:
Arthur's Stone on The Gower in Wales
The London Eye
By the sea, Sandbanks, Dorset
Chris, the tonality of your B&W XPAN shots are very nice - could you share abit of technical info on films & developers that you use, filters (if any), scanner used, etc.?
I still have no pictures from my Xpan yet, but plan to scan with my Minolta Dimage 5400.
I'm happy to share, although I'm not very 'technical' I'm afraid;
FILM - The three showing in this thread, Arthur's Stone is on Tri-X, the other two are FP4. The film is all commercially processed through a local photo shop.
SHOOT - I only rarely use the auto settings, preferring to use a (very) cheap hand held meter. The 45mm lens has a centre filter attached and I normally use a Lee mid yellow filter if I want to boost the sky contrast a little.
SCAN - Epson V700 at maximum resolution, set for black and white negative and scanned as 16bit greyscale. I adjust the histogram to make the scan just very slightly flat in contrast.
PROCESS - Photoshop Elements 6, avoid cropping if possible, adjust levels, a little burning or dodging if necessary and convert to RGB so that I can add a little warmth. Judicious use of Unsharp Mask.
That's it, the rest of course is just pure genius ;) :D
