x-pro2: 69 improvements?
aizan
9:50 PM
Can we get to 69 improvements on the X-Pro2? 37 more to go!
1) PDAF.
2) Active infrared autofocus.
3) Longer battery life.
4) Adjustable minimum shutter speed in Auto ISO.
5) Framelines and focus spot stay in place in manual focus mode or AF-lock, even if you haven't half-pressed the shutter button.
6) More accurate framelines (95% coverage?).
7) Customizable framelines, for both Fuji XF and legacy lenses.
8) Aperture chatter.
9) Faster EVF refresh rate.
10) Focus peaking with several color options.
11) Built-in diopter adjustment.
12) Sensor-based image stabilization.
13) Centered tripod socket.
14) Battery can only go in one way.
15) Easier access to SD card, needs more space around it.
16) Larger buffer.
17) Faster write speeds.
18) Shorter throw to the shutter button.
19) Improved feel to buttons.
20) Turn Playback button into custom function button (e.g., AF point selection), allow rotating dial to scroll through AF points, and move playback to a new fourth button on the left side of the LCD screen.
21) Customizable Q menu.
22) High-res LCD, ~1 MP.
23) Slightly deeper and shorter front grip.
24) Histogram option for instant review.
25) Reduced moire and aliasing in video.
26) Manual exposure in video mode, 50 Mbps at 1080p 24/25/30 fps, with mic/headphone jacks, mini HDMI, USB 2.0, and audio levels.
27) Weather sealing.
28) Built-in Wi-Fi.
29) Customizable file naming convention (e.g., camera 1, camera 2.)
30) Shots in continuous mode should "stay in line" with single shot mode file.
31) Cordless battery charger.
32) Battery status in %.
i believe fuji touted this 'line' respecting the recently released fuji x20. as an x10 and an x20 owner let me suggest this: make sure one of those 69 changes is improved vs decreased IQ.
tony
