XP2 in Diafine
MPerson
7:56 AM
On the beach - Dungeness area.
I have read about doing it and most of the examples I have seen were iffy/OK. Decided to try myself - each bath for 5 mins, water stop and alkaline fix 6 mins.
MP | Cron 35 ASPH | XP2 Super @ 400 | Diafine 5 + 5 | Coolscan
100% crop
I plan on testing some more. Method and a couple more examples.
Also try ID11/D76 for 18 minutes, 1:1, 20 degrees, normal agitation (every minute, as I recall).
This came from one of the technical guys at Ilford! It worked well, although I think the C41 process has the edge. Something to experiment with, though.
Ray
I also did not know one could develop a C-41 chromogenic film with B&W chems. When you do this and then scan, can you still use ICE to remove any dust or scratches? This is the primary reason I usually go with XP2 over a traditional B&W like Tri-X or FP4.
Anyone tried D-76? I have some of this on hand, as well as an unused roll of XP2.
na.. its just like silver, id11 two 12-min at 21, it could have benefited from a bit more exposure
