XPan vs. Epson 4990
drjoke
6:53 AM
How may I scan XPan negatives? I am using Epson Scan, and I do not find options for setting frame size to match XPan. Is there a setting in the software that allows me to match XPan negatives?
Fooled me too!
Fooled me too!
Just change the preview type to normal rather than thumbnail and it should work fine - you need to use this setting with everything other than standard 35mm negs/slides.
Mike
I tried that, but I end up having to manually select each frame with the marquee tool. Is there an automatic way?
After selecting one 24 x 65 (I think) you have the option to copy the selection using one of the icons in the upper left side of the window. Check enlarged version and trim slightly over the frame. Before clicking on scan, select All in the left pane of the window, then select some options, like dust removal and go.
Good luck
