Xpro3 EVF and OVF questions.
Huss
3:27 PM
CA
First off, the menus suck and the online instruction manual is not much help..
1. If I use the EVF via the viewfinder, how can I magnify the image?
2. If I use the OVF, how can I brighten the frame lines for outside shooting? I can only see the setting to brighten them if I am using a manually adapted lens and this is greyed out if a Fuji AF lens is mounted.
Thanks!
Daisy shot with Leica MacroElmar-M 90 f4 and ClassicNegative simulation.
On behalf of Ko.Fe. and myself, thank you Daisy.
And I hope someone can answer your question eventually.
Answered on fredmiranda.com:
Set your rear command dial press feature to magnify. To set it up press and hold the Disp/Back button. When the function button menu appears cycle through the diagram until you see the rear command dial highlighted and then choose focus check. Done.
