Yashica battery question
optikhit
Photo gear player
11:14 AM
Sorry if this question has been asked before. My Yashica GSN is now on the way. I just buy a PX28A battery for the camera. I wonder to know can the PX28A be directly used in the camera? Because it is 6V not 5.6V. And furthermore, are there any other alternative ways for GSN's battery? Thanks a lot.
I'm pretty sure the 6v PX28A works perfectly in the GSN. A stack of 4 button cells would work too. You just need to keep then touching the contacts--some use a small spring and wrap the batteries to keep them still.
For some time I´ve been using a plastic tubing of a suitable diameter (printing calculator roll core) to hold a PX28 battery inside, plus a short spring with a copper contact for the battery + terminal.
Unfortunately PX28 alkaline batteries don´t last more than 2/3 months (I think they should last at least twice) but they are cheap enough to carry allways a couple of spares in my bag.
I didn´t find yet another suitable battery for the GSN, but to be honest, I didn´t check all the batteries available at this moment. Four 1.5V silver oxide cells will also be OK, as derevaun said. Perhaps silver oxide cells would last longer than a PX28, but I didn´t make any test. in this case, the batteries should be insulated from the camera´s battery compartment.
Good luck.
Ernesto.
Thank you guys, suggestions are helpful. I now know how to do it, but I still worry about the different voltage. Then we can have many choices, for instance, 4*LR44cell, 4*625cell, PX28A, and etc. Am I right?
Thanks again.
Supposedly the GSN's have an internal regulator that ensures that the correct voltage is sent to the meter. I think this was because the old mercury batteries tended to fluctuate in voltage... I wish I could remember where I read it. Yashica Guy's website, maybe. Anyhow, hope that helps.
