Yashica Electro Half
avidmaster
V is for Voigtlander
3:43 AM
Hi All,
New to the forum and really excited to be a part. I came across this half frame a few weeks ago. I snapped it up on ebay when the seller listed it as an Electro 35 GSN. I knew right away that it was not that at all.
Overall nice exterior. Unfortunately, years of mercury battery leakage has pretty much destroyed the electronics. Didn't pay much so it's a nice display piece and historical artifact.
Thanks for looking!
Mike
Yashica Electro Half by Michael Kaplan, on Flickr
Hi All,
Thanks for looking!
Mike
Now, if I could only see the photos......
PF
Thanks. Interesting camera. Perhaps at some point, I'll dive into it to see if I can facilitate any repairs. For now, though, I have other projects on the table.
Mike
Very clean, pity about the electronics.
Been a fan of 35mm half frame for decades. If you ever decide to try it out then my recommendation would be the original Olympus Pen, introduced in 1959. They are full manual with no meter. The 2 blade Copal shutter is more often found working than the 5 blade Copal on the higher spec Pen S 2.8 and (much rarer S3.5).
Not a wide range shutter, 1/25-1/200 +B, it is still usually sufficient.
Nice, thanks for the rec. I'm afraid this little camera has more issues than the electronics. Aperture blades are at issue, as well and a modest dive into camera through the top and bottom plates revealed a wiring nightmare that makes the Electro 35 look like a walk in the park.
This one is, unfortunately, a very attractive bookend.
Mike
This is why I prefer beater cameras to pristine examples. Years of dealing w/ erratic FSU stuff taught me that one. If it's beat up, it's going to work fine. If it looks mint, there's a reason for that, and it's usually not a good one.
I can see them now! Too bad about the battery issue, but that's fairly common with any Yashica of that era that you find. It wouldn't be so bad if they weren't battery dependent.
The 72-E was an earlier model with selenium metering that sometimes you can find one still in operating condition. Mine overexposed quite a bit, which could also be indicative of a slow shutter, but I think maybe it would do better with b&w film.
Yashica 72-E Half Frame 35mm by P F McFarland, on Flickr
A somewhat corrected image
Bedford County, VA Masonic Lodge circa 1895-1906 by P F McFarland, on Flickr
PF
