Yashica GX asa setting
DaveP
4:47 AM
Can anyone tell me the correct asa for each detent for the asa setting tab? It looks confusing as you can set it below the lowest number,50, and go past the highest number,800. My issue is 200, am I supposed to set the tab inbetween the dots for 200 or is one of the dots 200? Thanks1
I think you set it between the dots as it is notched at the 200 mark.
I'm using 100 asa and it's set between
DON
Set it between the dots above the numbers. The dial allows you to fine-tune a little if your camera is over/under exposing.
Thanks! I was wondering as my photos are a little lighter than I like. I got confused when I tried matching asa numbers with the detents for the tab.
