Yashica J Focusing Problem
The rangefinder image is not moving.
The lens seems somewhat focused, but nothing changes when moving the focus lever.
A lot of the older Yashica rangefinders were very similar, sometimes using the same parts from one model to the next, so John's YK work will help you.
Make sure though that the lens is actually moving when you push the focus lever, as sometimes they will decouple. Most likely though it is just a stuck lever from old lubricant. When you re-lube it, I suggest using a synthetic like Super Lube®. A little goes a long way.
Once you get it sorted out, you should be able to get results like these https://flic.kr/s/aHsjFyDjGA
PF
I recently had the same problem with a late 50's Ricoh 500
and was able to access the focus lever from inside the film gate.
No top removal necessary. I just applied some naptha judiciously
to the lever hinge point and worked it up and down till the old grease
loosened up.
Don't think it works that way on the Yashica, though.
I have a post here: Yashica YK rangefinder | The Camera Collector covering the Yashica YK, an older cousin of the J. This shows the rangefinder, and how to open the top of the camera to access it. Your problem is probably caused by old lubricant gumming up the linkages under the rangefinder.
hi, i know this was written a long time ago, but i'm newly into film photography and running into a similar issue with the YK. looks like the photos in this thread have expired / are no longer appearing, do you still have photos of your opening up the camera to repair the rangefinder?
