AlejandroI
Hi fellow forum members, I just got this lens and will like to get a lens hood mostly for protecting the front element, and cutting down the lens flare when needed.
Do you know about any alternatives to the original one?
I dont feel like paying 140 euros for a lens hood. Has anyone used the ones been sold in Ebay, or even the 7artisans one?
Thank!
Thank!
kram
Vented aluminium hoods are on ebay for less than £10 from PRC vendors. I have one.
Huss
The thing that’s really nice about the OEM hoods is the spring bayonet fitting. If that doesnt matter then just pick up a $5 one off ebay. I use those on my lenses that do not have that option.
AlejandroI
What's spring bayonet fitting? What are the benefits? Thanks!
The hood fits on the chrome outer bayonet ring around the filter thread and locks into place in the correct position held there by a spring so the hood won't move. The hood can also be mounted in the reversed position. Another advantages is the filter thread is not used by the hood, which makes using filters easier.
But here's the thing. the ZM 35/1.4 is superbly flair resistant and doesn't really need a hood. I don't use one on mine, and instead just use a decent UV filter to protect the front element. No issues so far.
narsuitus
AlejandroI
Thanks to all! I went for one of the cheap versions, but in Amazon.de.
Will let you know how it goes.
AlejandroI
AlejandroI
So I ended buying the following hood from amazon... https://www.amazon.de/gp/product/B06WD7XWTC/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Sadly even thou built construction is great, it causes a slight vignetting in the lens. Not sure i will be using...
