spacedementia87
Hi there everyone, I have recently acquired a Zeiss ikon contina 1b.
When I first got it I would it on and clicked the shutter. All seemed fine. Then I found that it would not wind on again no better what I tired nor would the shutter go.
I took off the front of the camera using the screws inside of the camera body
After filling a little I managed to get it to wind on again, but this seems like it was a mistake because now the bar across the top which has a ratchet on it (does it tension the shutter?) is stuck out and I can't get it back in. I can't seem to move anything.
The shutter is still not firing though even when trying the lever on the back of the lens assembly.
Any help would be great.
Thank you.
Thank you.
