Joerg
Dilettant
so I got my new ZI and was wondering about the meter sensitivity pattern.
After a few rolls of film I worry less when using film, most of the exposures are spot on
, the rest is me not thinking about metering
But I inquired with Zeiss anyway and got the meter pattern sent.
Here is an explanation for the pattern:
"Due to the position of the metering cell the area of peak sensitivity is slightly off-axis and shifted to the lower left. This is intended to reduce the influence of bright sky both in horizontal and vertical (right hand up) frames."
Ciao
Joerg
Ciao
Joerg
Nachkebia
Nice! thanks for the information! I have shot around 5-6 rolls and I have to say all of the images are spot on
back alley
IMAGES
very cool, thanks joerg!
did we know that you were waiting on a zi?
joe
joe
Joerg
Dilettant
back alley said:very cool, thanks joerg!
joe
Not really............
But I sold my M2 and a Canon IVbS to make room for the ZI
So you could have known......:angel:
BTW I am very happy with the ZI. i am a big fan of AP exposure mode and it is done right with the ZI. On Saturday I will check out a M7 (be forewarned PN) to get a rough comparison.
Ciao
joerg
tfelton
Ted
I wish I hadn't seen that. Now I'll be worrying about the pattern being off center.
Although, I would say that the ZI meter has been excellent so the meter and I get along very well.
back alley
IMAGES
being a little off never hurt me...
willie_901
Thank you very much for sharing this.
Mazurka
tfelton said:I wish I hadn't seen that. Now I'll be worrying about the pattern being off center.
You probably worry even more about the RF/viewfinder which is much further away from the optical centre than the metering pattern.
Captain
[This is intended to reduce the influence of bright sky both in horizontal and vertical (right hand up) frames."/QUOTE]
Sorry but thats just a bit of spin. The meter patern of some of the Bessas is off center purely because they couldnt engineer it otherwise. The ZI is supposed to be a bit closer to center than the earlier Bessas though. Personally I think perfect center is best especially for using exposure lock facility but as others have noted they havent found it to be a problem.
tfelton
Ted
I don't worry about the viewfinder, I just don't need the off center compensation for the metering. I know how to do that myself. However, as I said, the ZI has proven to be excellent with regards to metering so I will try to forget the off center part.Mazurka said:You probably worry even more about the RF/viewfinder which is much further away from the optical centre than the metering pattern.![]()
Ted
grantray
Wow, now I know why i've missed some shots. I've been wondering what the pattern is for some time. Thanks for the heads-up on the info.
-grant
-grant
