Zeiss Ikon Super Ikonta 534/16 frame spacing
CharlesDAMorgan
8:04 AM
This is a gorgeous folder which I occasionally use as a medium format option when overloaded with 35mm kit. The problem though has been the film frame spacing, the advance mechanism perfectly calibrated for Zeiss Ikon film, which was thicker than modern and, of course, not made now.
I'd heard of adding a length of Post It notes on to the film paper backing, but nothing precise, so I stuck a 6cm length on to the Kodak Tmax 400 paper backing and wound that on.
Result just out of the tank - framing perfect, just one missing shot at the start from user incompetence, but a full 12 exposures possible. Apologies for the slight out of focusness but my XT30 hunts a bit in close ups.
Start of film
End of film
Post it length and position (the latter simply to ensure it was tightly wound)
Apologies if this is a solution that others have tried, I was entertained by the serendipity of getting it right with 6cm of Post it first time! Results may well vary with other films.
Cool. I've tried modifying my Pentax 6x7 suffering from the same issue without success. I will try this.
Well done! - I may have to try this technique with my Perkeo II, which currently yields 13 frames on a roll of 120.
Very cool! This maybe a dumb question but dont these. cameras have the red window to show where to wind the film?
They do, and also internal markings, but the problem is in the film advance which is scaled precisely for each frame of old film thickness. As new film and paper backing is thinner, the circumference of the wind on is less than originally designed so over the length of the film the frames run closer (as there is less of a gap) and then overlap. I think my last unadjusted film had 9 usable frames.
