Zeiss Jena and T coating?
santino
FSU gear head
10:38 AM
Hi all!
Some time ago I got a Carl Zeiss Jena 3,5 50mm Tessar (collapsible) in Contax/Kiev mount. It's marked with a red T. I thought there were only west german T coated lenses?
I couldn't find any info about exactly that lens.
here's a pic.
do you have any info about that lens? year etc. ?
The lens is a post WW2 CZJ, as evidenced by the serial number that is higher than 3 million. All post-WW2 lenses, East and West, were "T" coated. CZJ began to routinely coat lenses in the late 1930s, athough not all lenses were coated during this era.
Your postwar CZJ 50/3.5 is a nice lens, and is sometimes called the "black line" Tessar because of the paint-filled circle on the front of the bezel. My reference book by John Keesing states that the lens was probably made in 1945 or soon after. Someone with the Theile book on Zeiss lenses should be able to supply approximate manufacturing dates.
Santino,
H. Thiele's reference book (p. 72) says: "card #295, Tessar, 1/3.5, 5cm, calculated 1931-02-27, batch of 1.200, s/n 3.100.601-3.101.800, Contax mount, prod. date 1947-12-18"
So your lens is a post-war lens of a pre-war design.
Lens coating has been discussed in this forum, I suppose, but without going into too much detail (and quarreling who was the first to invent it), I will try to summarize what I think can be said safely.
The German patent for lens coating was registered by Alexander Smakula of Carl Zeiss Jena in 1935, issued in 1937, and published in November, 1944 - indicating that it was kept as a secret until it had become clear that the allies were capable of producing coated lenses as well as their axis counterparts; there are rumours on the net that lens coating had been invented earlier (by simply tarnishing lenses on the air or immersing them in calcium salts as this had been known since the turn of the last cerntury), and that viable coating had been invented by the Carl P. Goerz factory in Berlin for their field glasses, but I have not seen proof of the latter; obviously a similar invention had been made in the U.S. in the mid-thirties, I have seen a document about that but keep forgetting the name of the inventors. Japanese periscopes are also being said to have been coated prior to WWII, but I have also not seen any documents.
As far as CZJ is concerned, coated and uncoated lenses were produced during the pre-war period and wartime, and there is much in favour of the theory that coated lenses were primarily sold to the military and to researchers; at least my issue of "Neue Foto Schule" by Hans Windisch, a very detailed book for the amateur market, does refer to light loss along reflecting surfaces, but not to lens coating at all as late as 1940, and CZJ advertising from the 1930s and early 1940s does not, either.
By the end of WWII it was clear that lens coating would be available to anybody wanting to put some effort in the issue - and that the CZJ patents would not be of much interest in an occupied country; I have often heard the claim that every lens leaving the CZJ plant after WWII was coated (this issue would still have to be settled in my opinion, circumstances seem to have been rather chaotic, serial numbers from some 2.700.000 were in disarray, coated lenses were not always marked with the red "T", uncoated lenses were coated after-market - we will probably never know).
I have enclosed a post-war document about the Smakula lens coating patent from which, in the middle of the page, the exact patent dates can be derived.
This being said -
forget about the stuff and enjoy shooting that lens!
Jesko
I have your lens's brother (or sister), #3100751.
Enjoy.
santino said:
Hi all!
here's a pic.
As an aside to the original query: What is the actual difference between the - now historic - T coating of the 1930s to 1960s (?) and the current T* coating on Zeiss lenses?
What has been improved with T*? Anyone have kowledge or an idea? Thanks!
I think the T* is multicoating, as opposed to single-coating. You might want to ask Zeiss directly:
http://www.zeiss.de/C12567A8003B58B9/Anfrage?OpenForm
