Zeiss ZM Top Plate screw size
freeranger
8:43 PM
Hello, I hope someone can help me. The 2 screws that hold the top-plate of my ZM have just...disappeared!!! Must have come loose and dropped out.
Do any of you know the specifications of the screws so I can replace them? Thank you
Those screws seem to commonly fall out. Mine were loose when I got the camera and I know others have complained. Unfortunately I don't have the camera any more so can't check the size but most camera screws tend to be either 1.6mm or 2mm so you could try that. I also seem to remember someone saying they got replacements from Zeiss. A while ago admittedly but could be worth contacting them to see if they can supply them.
If they're standard size, microtools is a source. I've purchased 1.6mm and similar small screws from them. They have both a North American and European presence.
