AlexBurdov
News from Russia - Krasnogorsk
http://www.celler.ru/forum/index-25/topic-119573.html
Excuse me for my bad english.
Translate
New Zenit - base "Narcis" with 4/3 matrix and with 28.8 flange focal distance.
Translate
pvdhaar
Peter
28.8mm, isn't that LTM territory?
Bryce
Was the drawing not of a digital camera?
Wish I could read the text!
AlexBurdov
This digital cameraBryce said:Was the drawing not of a digital camera?
Manual focus, but SLR.
pvdhaar
Peter
I ran it through babelfish, and this sounded quite interesting. Digital, 4/3 sensor. Primarily for use with manual focus lenses, AF lenses would 'not be ideal'. The question remains, which lenses will be compatible. If they shave off a further 1mm, and have an M-mount, they'd have something really interesting! But they may equally well decide to go 4/3 all the way.. couldn't really tell from the text..Bryce said:Was the drawing not of a digital camera?
Girmantas
It can fit M lenses too!
V
varjag
Guest
Let's see how it works out. I admit the idea is great.
Was looking at original Narciss the other day, precisely for it's short working distance. A manual, compact DSLR that takes RF lenses would be something, and *I* sure will buy it.
For those few who can't read Russian here
The text states that design goal is to have work distance shorter than 28.8mm, so that "the widest range of small format optics can be adapted", including "deeply protruding RF lenses in MLU mode". Two types of shutters are considered, cloth one and copal-style.
pvdhaar
Peter
Does it explicitly state that?Girmantas said:It can fit M lenses too!
These have a 27.8mm register. The LTM lenses are 28.8mm, which is the target mentioned..
V
varjag
Guest
It says "a bit shorter than 28.8".pvdhaar said:The LTM lenses are 28.8mm, which is the target mentioned..
Sparrow
Probably just a re-badged Fed 8
pvdhaar
Peter
Please elaborate..Sparrow said:Probably just a re-badged Fed 8
You mean it's vaporware?
Sparrow
pvdhaar said:Please elaborate..
I rather amusing satire that ran in a few threads, on this board, around the time of the m8’s début
V
varjag
Guest
It can't be, the Kharkov factory is in Ukraine nowSparrow said:Probably just a re-badged Fed 8
brachal
Refrigerated User
Neither is an improvement on the old Fed-2 Digital Back.
Sparrow
brachal said:Neither is an improvement on the old Fed-2 Digital Back.
hope springs eternal………….
rbiemer
Unabashed Amateur
As peter did, I ran the site through Babelfish. And I think the important part of the discussion there is that apparently there is real money for this project. (Eugene, am I reading the translation right on this point?)
I am a bit unclear about this page, though. Is it a Russian/Ukrainian discussion board and are the folks--particularly "Ivan N" involved with KMZ or outsiders reacting to some news they heard?
Exciting news, I think!
Rob
Rob
erikhaugsby
killer of threads
varjag said:It says "a bit shorter than 28.8".
And even if it isn't 27.8mm M lenses could still be mounted and used effectively; the only negative would be loss of infinity focusing.
Yum.
shadowfox
Darkroom printing lives
Wow, that Zenit-N1 looks very sleek with detachable(?) LCD screen.
Um, does the article talk about the 4/3 sensor as in 4/3rd system pioneered by Olympus?
V
varjag
Guest
Yes, it talks about 4/3 sensor, as that's the one they plan for. There's also mention of supporting 4/3 system lenses, although it "might not be entirely convenient on a manual body".
They mention putting some work into camera's bayonet, to my understanding desinged with adapters/3rd party compatibility in mind. Regarding the working distance, wording is "it is slightly shorter than it was on Narciss (28.8mm)".
Rob, you are correct, per the text, the real money were assigned. The project existed already though, albeit unclear in which stage.
Text also mentions that parts of original Narciss are likely to be "adapted and reused", must be a way to save on entirely new production line. My guess is molding forms for chassis. That also explains the modularity perhaps. The article suggests a pentaprism and no LCD configuration is default, replacable with digital sensor/LCD back combo.
sweathog
MY first reaction (well, second after excitement) was that is this comes to fruition, it is going to be hella expensive. At least that's what I think.
