Zorki 4 self timing lever seal
nickbownz
5:28 AM
Just purchased a Zorki 4, and the first roll of film shows a light leak. My research as well as my own investigation of the camera leads me to believe that the leak is coming from the self timing lever, taking it off I found it missing the seal that's supposed to be around the linkage between the winding mechanism and the lever itself.
I need to fabricate a replacement seal, but I've never seen one, and the only picture I could find on the internet had been photoshop filtered into oblivion.
I need to know the approximate dimensions and materials of the seal, pictures would be ideal.
Thank you,
Unfortunately, RFF tells me I'm over my limit for pictures, so I can't post one. The seal is a felt washer, it's 8mm across with a 4mm hole and it's about 1mm thick. It fits nearest to the body, slipping over the rear shaft of the small black drive-piece that connects the wind-lever to the timer mechanics.
Welcome to RFF, by the way. I hope you get to enjoy the Zorki, let us know how you get on.
problem solved
problem solved
The felt seal did the trick, all the pictures from the last roll turned out perfectly.
