vmk
Rangefinder User
This 4K works fine with the exception of frame spacing being narrow between all frames. They don't touch but are so close to each other that cutting is a bit of a pain. Any ideas where to start looking? (It would also be nice if the spacing did't fall on perforations but, let's not ask for too much!)
Mauro
Mauro
I experienced a similar problem with my Kiev 4.
With regard to spacing on perforations, you may need to trim the felt on the film cartridge: if it is too much, the cartridge does not fit perfectly its place inside the camera. The film advance is ruled by the sprocket wheel inside the camera , and not by the winding reel: this reel (where the film, once exposed, is wound up) should slip a little bit to compensate the growing diameter of the film roll while winding up.
I hope you can understand my explanation: it is easier to check it, than to explain.
Enjoy your Zorki, a great camera indeed!
