Zorki 4k questions
winston_smith
4:37 PM
Hi everyone,
This is my first post on this forum and I have to warn you that I'm a complete newbie in (film) photography. Being nostalgic by nature, I recently bought a Zorki 4K on ebay. I paid quite a bit on it and it really seems to be in fantastic shape. I loaded it up and I already took the first shots. However, this evening I did a little "research" on Zorki 4K on the internet and I found something puzzling. Basically, all Zorki 4K are supposed to have a fixed take up spool. While I cannot open the camera now (I don't want to lose the film), I clearly remember that mine did not have a fixed one. I was even close to losing it, actually. What do you think? As I know nothing about cameras, I am little bit worried that maybe I was duped.
Thank you for your time and please excuse me for bothering you with such silly questions.
W.S.
Hi and thank you for your help. I checked the manual earlier, but that didn't solve my dilemma. Maybe I'm just a little paranoid, but I must admit I find it hard to get over it as I lack the necessary information about these cameras.
Thank you,
W.S.
I don't have a Zorki 4K, but Zorki 4 which from I learn are basically the same camera without the lever wind of 4K.
The Zorki 4's take-up spool are removable, to a point it drops out when the cover is open and some got lost as a result.
I am guessing, your 4K spool is also removable.
Only the Zorki 6 had the fixed takeup spool, IIRC. All other models had the standard LTM type removable spool.
William
Mine has a fixed take up
My Zorki 4K, serial number77143***, has a fixed take up spool. Mine also has the printed, as opposed to the engraved shutter speeds. I understand that one variation of the 4k had the shutter speed dial engraved. Since the print is beginning to go, I understand the advantage of the engraving.
Oh, sweet mystery of FSU cameras.
Dave
The 4K certainly normally has a fixed take-up spool. Apart from the lever wind it is the other feature that distinguishes it from a Zorki-4.
Am told that the Russian word for lever begins with K, well, they actually told me the word, but all I recall is the K. ;-)
Regards, John
Hi everyone and thank you so much for all your help. I have to live with the idea that I have a one of a kind Zorki 4K, it seems. :) When I'll unload the first film, I'll check more closely the take up spool and I'll post my findings here.
Thank you,
W.S.
My 4K has a fixed spool as well, but you can never be sure with these commie cams; Often they have been tampered with at the kitchen table during the long Russian winter nights. My first Zorki 4 did not have a take up spool at all. My FED 3 has a brass take up spool which is clearly homemade, and I have seen a FED 4 with a spool glued on that was almost certainly from a FP4 cartridge. Who cares as long as the spool does its job? :rolleyes:
Well, you can be pretty sure that the Zorki-4K originally had a fixed spool, because reference was made to this feature in the manual supplied with the camera.
