Zorki 6 repair/cla help web pages
kievman
Kievman
11:59 AM
I recently purchased a very clean Zorki 6, but it has one problem- a very stiff shutter release and slight rangefinder misaligment. I was wondering if there was any good repair/CLA websites/pages out there for the Zorki 6?. I did a few searches, but didn't have much luck.... any suggestions, Anybody? - Michael
There was a thread on here detailing a complete strip-down of the Zorki 6 - have a search in this sub-forum.
The RF is adjusted the same as most other FSUs - The RF window has a bezel, behind which is a prism window to rotate for the vertical adjustment. Once you've done that (if needed) then there's a tiny screw behind one of the badge screws (I can't remember which) to adjust the infinity alignment. The RF sensor cam can be adjusted to correct the 1m alignment. Adjusting the cam also messes up the infinity though - and vice-versa - so it's a case of repeat each adjustment until both are correct. Make very small adjustments and check you are going the right way!
