Zorki shutter tension adjustment
limnidytis
6:58 PM
I recently acquired a Zorki C which generally worked but the shutters were slow and would stop after a few minutes in cold weather. I disassembled the camera and cleaned the mechanisms - there was a lot of old caked grease in the restrictor gear mechanism which I think was most of the problem. Anyway, I want to retension the curtains now, and have read through the various postings here and elsewhere about how to retension the curtains. Maybe I missed the information, but it was not clear to me what position the shutter should be in when I wind up the take up rollers - should the shutter be cocked or released? This would seem to influence the final tension when the shutter is cocked.
Thanks
The curtain roller tensions are set or adjusted with the shutter released. About 4 turns on the first curtain (rear roller) and about three turns on the second (front roller) should get you in the ballpark - adjust as needed from there.
Derk
Spot-on answer from Penny Lane. If the mechanism is clean and properly lubricated you may get away with as little as 2 turns on first and 1 turn on the second roller but chances are it'll be nearer 3-4 and 2-3. If you need more than about 5 and 4 there's a problem somewhere.
Thanks. So when I wind up the shutter to cock it, more tension is applied, and the initial tension is the least tension applied to the curtains?
I read the Leica IIIf repair book, but it says that the initial tension is applied with the curtains in the "starting position" - but I could not discern precisely what "starting position" meant.
Set the tension with the shutter uncocked, i.e. at the least-tension position. The number of turns mentioned above applies to this method. I'm not an expert on how Leica does it so I can't comment if it's the same or not.
"starting position" means in unwind position. The first curtain roller is tensioned always a little more than the second roller. You should check the 1/20 sec or 1/30 sec and the top speed 1/500 sec. If the 1/500 sec is closing without "capping" than all other speeds should be ok.
Thanks for the info.
