JFB
Hi! Where can I get my lens repaired (Canada and US). Rotating is getting sticky and some grease is starting to show on the blades... Thanking you for your help!
KoNickon
Nick Merritt
Hi -- those are rare and sought after lenses, well worth good servicing. You might try focalpointlens.com or Paul Ebel Lens Repair (don't know the web address offhand, but Google it). John Van Stelton at Focal Point is excellent to deal with; Ebel has a fine reputation also. I'm sure others will have good recommendations as well.
JFB
Advice for zunow lenses
Thank you for your reply. Two references I am going to contact, however far away from Montreal, Canada. Any advice to insure adequate coverage of any risks to ship such an expensive lens...?
Best regards,
Best regards,
Vickko
Hello, what Zunow's are they? 50mm f1.1? I hear the 50mm f1.1 is very hard to repair.
In any case, I'm in Ottawa, and sending to the US isn't a problem. Postal Service will insure to $1000 CAD. FEDEX/Purolator will insure to much higher.
regards
Vick
regards
Vick
David Murphy
These are simple problems for any competent camera repair tech in any city.
JFB said:Hi! Where can I get my lens repaired (Canada and US). Rotating is getting sticky and some grease is starting to show on the blades... Thanking you for your help!
JFB
Yes, f1.1... with a screw adaptor for a Leica M3.
Thanks for your advice.
Best regards
Best regards
