What you think of this strap?
ywenz
8:50 AM
Chicago
I think it works for DSLRs.. but a totally inelegant solution for the M8
http://www.camdapter.com/gallery.html
They are a pain in the neck for any camera. It makes it hard to put the camera down or in a bag - the strap grips your hand as it moves from the body. It is also makes the camera more bulky which I find annoying when placing in a bag.
looks great for a DSLR.....
I use Gordy's wrist strap and it works well.....not complicated...just a sturdy strap.
I have tried both. The first one adds considerable weight to the camera and does not work very well because the upper attachment point is in the wrong place. The metal piece on the bottom adds weight and bulk. The leather strap is nice if it worked. It really doesn't.
I also have the Sling and it works far better. The center of balance is right and you can actually let the camera dangle from your finger tips because it grips your fingers like a chinese finger cuff. It add no weight or bulk.
Having said that I find I actually prefer the hand grip with neither as I can carry it easily hanging from my fingers and it adds something to holding the camera securely.
I hope this helps.
I have a Sling from Lutz; I use it on a Bessa L- along with a longer string to carry the thing by when It needs it. For the Leicas, I use a shortish neck strap; it can ride my shoulder, (or my knee, if I'm sitting down) or I can drop it around my neck if need be. I wrap it around my wrist when shooting.
I use my left wrist, and carry the camera that way. When I lift the camera to my eye, my hand is on the lens barrel to focus- and my right hand, which is my dominant hand, is free to do other things- like shake hands or pick things up.
I have the Slings on all my M's they work fine and are not obtrusive and easy to pack camera away quickly. I asked for wider finger circumference measurements on my last order as i found the looser grip was more flexible in use. That pic with the M6 makes the grip to appear much more awkward than it is in actual use.
I used the Sling. Hated it as my fingers always got stuck in it. That may sound like a good thing (camera won't fall off) but it shucks when I need my hand and have to struggle for a minute to get my fingers out. Also, I never was able to hold the camera comfortably.
On my old film Eos 3000 I had a similar band strap. It worked well but it posed problems when putting the camera in a bag. It takes up space and always got in the way when I tried to get the camera out. One plus was that I could just pull the camera out of the bag from that strap. 🙂
I'm now using Gordy's straps. I've never had it so good. They're sturdy, feel comfortable, the o-ring makes sure the strap is snug, and adding a carabiner lets you hook the camera to your belt when you need to tinkle. A quick flick of the wrist and the camera is back safely in your hand. 🙂
As an alternative to the Sling for my small RFs, I use the Optech wrist strap that is made out of foam rubber and has a plastic slide you can make the part around your wrist as tight as you like.
Op/Tech is good. I've been using their neck straps for at least a decade by now.
That wrist strap sounds very similar to the Gordy wrist straps, except for the foam (Gordon's are leather).
