Mamiya 6 and filters
marcwilson
7:45 AM
England
For users of Mamiya 6's out there.
Can you use 67mm filters on 58-67 step ring on the 50mm and 75mm lenses and still use the lens hoods?
This would make sense in only needing one set of filters to cover all 3 lenses.
Thanks,
Marc
Thanks.
My Mamiya kit arrives today and a step up ring tomorrow so I'll check then with my 67 filter.
If that does not work, and I want to stick with 67mm filters I'll try one of the various screw in metal hoods...
marcwilson said:
Thanks,
Marc
No. Also remember the larger filter will cut into the viewfinder frames (bottom right corner) for those lenses.
