Both scales right and left show magnification and you can adjust the exposure based on the reading. 3 1/2, 5, 8, and 11 all differ by 1 stop each step.
Calibration of the auto focus with a 1 in thick easel is done in two steps. Rotate the lens focus ring and lock in place with the sloted tab that slide around the perimeter. Use 10x or full up for this step.
Lower to 3 1/2 x and use the plated screw near the non illuminated disc that rides on the focus cam to make it focus at the small size. Lock into place. It is now calibrated for that lens only and will auto focus from 3.5 to 10 x
The lower position on the column is for no easel and putting the paper directly on the baseboard. To use a larger 12x16 easel which is slightly thicker, there is a spacer ring to raise the column clamp 1/4 in or so.
Use Hopp`s gun oil on the 6 oil points in the pallelogram arms.
If it is black round head model, you must have a short neck enlarging bulb. Good luck finding any. A 60 watt snow white household is the best substitute. Remove the printing with acetone. If you have a greg oblong, regular PH111 are just right. Center the filament side to side and raise /lower to achieve even illumination using the three screws on the top. Ph111 require full up.
