Beige tinted flash ?
btgc
2:32 PM
Hello, couldn't find any suitable forum for this case, so for a while post here.
Have received flash, for my unexperienced eye it works, though on front plastic element it has thin "light beige" tinted layer, I guess it's thin layer of glue which hardened when dried. To describe it more, I can say that it's semitransparent, I can see thin lines in structure of front element. Seems it can be gently scrubbed off with wooden tootpick, I just wonder why previous owner did it - to have permanent filter/diffuser on ?
Are you sure it's glue or such?
Anyway, if you can ask the previous owner, you'd find out pretty quickly what he did with it. 🙂
It reminds me thin layer of hardened epoxy glue, to be precise. As with all stuff coming from BAS*, I'm generally not very sure about previous owners 🙂
* BAS stands for "big auction site"
Probably prev. owner had specific needs or taste, so I assume. I just peeled off this thin layer and now flash is clear. Thanks all who helped out !
I'm sure it weren't nicotine deposit. Thin semitransparent film of hardened epoxy glue.
And to answer direct Q: I don't know previous owner, flash came from BAS.
wow...gold flash - is it used as term describing specific filtration or manufacturer ?
my flash is plain&basic vivitar 2800, eur5 deal.
Seems Rosco makes specialty products, though what I removed were clearly hand work, having in some places even traces of cracked air bubbles. It doesn't seemed to be sticky film in any way. Semihard coating, which I were able to remove with sewing needle, gently peeling it off.
