Tried out some Superia Reala 100...
fishtek
Don
4:25 AM
Shot a roll of Fujicolor Superia Reala 100 while wandering around my town the other day.....
Bright sunlight, lotsa contrast, maybe not the best time to shoot such a highly-saturated and contrasty film, but I wanted to see what it offered. Packed it in my Auto S2, and stuck on a hood I recently found. It's a bit too long, had some vignetting. Maybe I'll try the hood without the UV filter I screwed it into.
Anyhow, after having the film processed at my local drugstore, I took it home and scanned it at 1200 dpi. Wow, it this stuff saturated! I used the metering in the camera straight-up, no manipulation. Still felt the need for a bit of toning down the colors when I post-processed the images. I cleaned up some dust out the skies and applied a bit of USM, de-saturated a bit.
I think it deserves colorful landscapes or showy flowers, or riotous colors of any sort, and it seems to also lend a bit of snap to drab stuff, too. Interesting film. I'm gonna convert some of the images to b/w, and see what happens.
slainte'!
Don
Some nice shots. However, I've never thought of Reala, in either its original or Superia forms, as being a particularly saturated film.
slainte'!
Don
I always shoot Reala at 80 - I find it too saturated at 100 and too prone to dropping shadow detail. It's all about preference though as a friend swears I'm insane as he loves the Velvia-style saturation you can get out of it when rated at 100 in thick sunlight.
In my limited use, I think Reala is the best ASA 80-100 color negative film around. I have 10 rolls of 120 Reala in the fridge waiting for the right project with the Pentax 6x7. Great film!
venchka said:
In my limited use, I think Reala is the best ASA 80-100 color negative film around. Great film!
2nd that. My all time favorite color film. And easy to scan, too.
Roland.
I have either 6 or 10 rolls of this stuff that I shot in Fiji a few months ago waiting to be looked at. Maybe I should try and get round to it this weekend...
I have a cheap scanner at home and scan at 2400 dpi. But I think with a
good scanner you can go much, much higher than that.
Roland.
Some Reala landscapes (that I have shown before); all shot at 100 ASA:
Best,
Roland.
Same here
Same here
Roland.
I own the same scanner! 😀 Except mine wasn't cheap. 😱 I guess I should try some of my Reala negatives on my old scanner.
In the meantime, here is a very reduced copy of a professional scan around 3,900 DPI and a small crop from the original. A good lens helped bring out the best in Reala. A good photographer would have brought out the best in both.
Thanks T. You are too modest, Wayne, and you know it !
With a high contrast, high resolution lens like the 28/3.5 Color Skopar
(used in the third shot above)
one can easily generate landscapes 20" long with 35mm Reala. One of
the reasons I use rangefinders.
Roland.
Hmmm ... I don't quite like this film, when I scan it, the colors seems to always be washed out for me.
Maybe I got a bad batch.
Guess I'm gonna have to try scanning some of the negatives again at a higher dpi. My highest was 1200, and my Canon 4200f will go up to 3200, I think. Thanks! Oh, Ferider...them's terrific pictures!
Don
After having tested most every type of film that exist/existed I nowadays use only one colour film and that is Reala. I think the colours are great and you get a much softer tone than with most other films. I just like the outcome!
Jon
Yeah, I find it too saturated for my tastes at 100 ASA. I'll try it at 80 sometime. I remember reading on this forum that the 120 size Reala isn't as saturated and I have found this to be true. I like the medium format size even more than the 35mm size. A nice film in either case.
Joe
