Canon 85mm F2 Serenar - opinions?
CuS
11:34 AM
Virginia, USA
I just received a Canon 85mm F2 Serenar with both caps, finder and case for ~$100. It appears pristine.
I have yet to use it but I was wondering if any of you had a general opinion as to how it is best used and relative qualities.
Its to be used on a Bessa R3M Body for B&W.
Many Thanks!
I'll start, but I won't be much help. I have two Serenars a 100mm and a 35mm. The f3.5 35mm is just awful until f8. The f4 100mm is very good all the way though the f-stops. Both lenses are high quality build, and will take a beating. I know you won't do that, but they are tough. I had haze on the 35mm which I stupidly had cleaned, I should have just thrown it out. So check for haze, the 100 was very clear.
the 85/2 canon lens is great. very sharp and very heavy.
you could use it as a club to beat off muggers.
if you don't mind the weight it's a lens you could live with.
that being said, the cv 75 is also very sharp, much smaller and lighter.
I found it impossible to focus 85/2 on the R3a wide open and close up.
You will need a very well calibrated camera, and maybe want to add
a magnifier. Other than that, hold the combo by the lens ....
Best,
Roland.
charjohncarter said:
OT, Raid how old is you daughter now, in those 85mm photos she looks so young?
Dana is 4.5 years old now. She may have been 2.5-3 when the lens test was done on the tele lenses.
Best,
Roland.
Roland,
Could it be that something did not fit well in your R3a/85mm combo? I can focus easily with the Bessa T and my 85mm lens.
raid said:
Roland,
I believe the T has longer EBL, Raid. Similar to the LTM cameras
the 85/2 was built for.
Roland.
