M Mount Adapter question
I believe that you can use it with any LTM lens but it will only bring up the 28/90 frame lines.
Bob
Akiva
You should have no probs to mount the lens. But you will "tell" your camera that it's a 28/90 and so the camera won't bring the 35mm frame.
If you use it on a camera like the Epson R-D1, which has manual frame selection, it doesn't matter what's marked on the adapter.
What camera do you have? If it's a Bessa or another RF that you manually select the framelines then it doesn't matter.
Just manually select....I use an old Leica 50mm screw to M on my new R2A with my 35, and select the appropriate framelines and it seems to be just fine. I generally think the M mount, as long as it gets your lens on the body, youre good to go!
I have a Voigtlander 35/135 adapter that I'd love to trade for a 50/75 if anyone wants to trade.
Its in excellent shape, and I may have the box around if you need it.
I've been using tape to hold the frame selector lever on "50" on my M4-P w/ the 35 adapter and a Jupiter 8. Leicas require the correct adapter to pull up the right framelines- Bessas are nice in that you can manually select your framelines.
