- Local time
- 5:45 PM
- Joined
- Jun 23, 2005
- Messages
- 6,411
Timothyd,
Different camera respond differently to 50 years of use or non use. The Contax is a fine camera to start with. One of the head aches with some cameras is that you need to remember to wind the shutter before changing the shutter speed. Not doing this can cause either a major repair bill or the creation of a beautiful paperweight.
There have been several threads about not using a light meter and using paper charts for guidance. Read through several and look at making (printing, cutting out and taping with clear packing tape) a few to see how they work for you. While I love built in meters, I find myself using an incident light meter when ever I'm not sure. You can do fine with the paper based while you look at the different light meters. The Luna Pro was one of the best ever made, still holding value. I myself have a Sekonic L-318. Digital incident meter that can do a spot reading with an attachment, takes one AA battery. It's small and for me, perfect. Light meters are handy and another expense.
As you might stick with your Contax Google the model and find some free instruction manuals, print and learn them. The old manuals are great for being complete. Contax was the basis for the Nikon line of rangefinders. Nikon chose a different approach to the shutter, but if you like the Contax, you'll love Nikons. IMHO Nikon Rangefinders (S2, S3, SP, S4) are the perfect rangefinder for one hand operation (your right of course).
Rangefinders seem to work better with "Normal" (50mm or so) or wider angle lenses (35mm or less). Lots of folks love the 50, I never did till I got my Nikon S2. Now I've learned to love it. You can do a lot of great stuff with just a 50mm. If you like the 50 and want to go wider, look to either a 25mm or 28mm as your next step. Sticking with your Contax body, Stephen over at www.cameraquest.com still has a few SC wide angle lenses available (SC works on Nikon or Contax rangefinders). You could go with a 35mm, but I do not think there is enough difference.
You could switch over to Leica, but it's expensive and I would recommend kicking the tires on the Contax first. They have a fine shutter (that some times need repairing after 50 years) that is very quiet. There one guy out there that fixes them as good as new, take a look at the web and ask folks here on the Contax forum.
Good luck and keep asking questions. Most of us are very happy to help.
B2 (;->
B2 (;->
