SC-Skopar 25mm - loose mount?
dsymes
10:06 AM
Portland, OR
I've just received a 25mm SC-Skopar which mounts quite loosely on both my IIIa and on my Bessa R2-C. Is this typical of CV lenses in the Nikon/Contax mount? Can it be adjusted?
make sure there is a problem.
both the camera body's focusing helical and the lens focusing helical have to be set to infinity before mounting the lens. if that was not done, that could cause the looseness.
Stephen
Thanks for the quick replies. Yes, the lens is mounted correctly with the body locked on infinite and the lens set to infinite. I went back and compared it to my other external bayonet lenses, of which I have five. This one was very slightly loose in depth (front to bath) - and about 1/16th inch loose in rotation after lock.
