stuken
I learned on the Patterson tanks, and now use both steel and plastic. Theres pros and cons to both systems, The steel reels are a little harder to load, but not a huge problem once you get used to it. The nice thing about using the steel tanks and reels is you use less chemicals.
I never had a problem with gummed up reels, I just rinse them throughly in warm water after use, along with every other part of the tank.
Patterson reels are quite stiff when they're new, but if you use them for a while they get alot easier to pull them apart. I pull them apart to get my film out.
