gdi
HeHe! I think it is a testiment to the confusion that this thread was moved from the M8 forum to the Optics and Lenses forum! 😀
rxmd said:No.
Just to back this up with some numbers, I have here a medium format wideangle, a Zeiss Jena Flektogon MC 50/f4. Quite a decent lens if I may add this. Here's a couple of hyperfocal distances from the DOF scale engraved on the lens:
f/22: ca 1.8m
f/11: ca 3.5m
f/5.6: ca 6.5m
This is from a 50mm lens. Now Ned, take a Leica 50 of your choice, look at its DOF scale and compare. Then tell me if the DOF markings on my Flektogon are going to be of any use if I use it on a 35mm body. We notice that the 35mm body is a crop camera relative to the sensor format that the DOF scale on the Flektogon was designed for. Then tell me if the DOF scale on your Leica lens is any use on a crop camera.
Philipp
All I've done is put a lens on a camera with a smaller sensor and take a look at whether its DOF scale is still correct. As per your first post in this thread, it should be, but it isn't.NB23 said:Don't mix apples and oranges.
rxmd said:All I've done is put a lens on a camera with a smaller sensor and take a look at whether its DOF scale is still correct. As per your first post in this thread, it should be, but it isn't.
Where did I compare apples and oranges? If you think the situation should be that fundamentally different between a lens with a DOF scale designed for 56x56mm on a 24x36mm sensor, and a lens with a DOF scale designed for 24x36mm on a 18x27mm sensor, it would be interesting why.
Philipp
NB23 said:Ok... I'll come up and post my own samples. Either tonight or tomorrow evening.
greypilgrim said:The one thing that is a "truth" is that DOF is an illusion. By definition, there is only a single plane that is in focus. DOF is purely about the appearance of objects being in focus. There are many quotes at the site above that state this (and it is true based on the "laws" of optics, basic physics).
No, they have higher resolution. A vulture has even higher, and its eye has a "tele"' part in the centre allowing him to identify small objects on the ground. Just imagine eyes with varialble enlargement and DOF; it would drive optics designers totally over the edge! 😀tomasis said:Is it because cat has noctilux eyes? I know how cats could move along nicely at nights so this explains shorter dof also 🙂 damn our human elmar eyes 😉
