I must be crazy....
I must be crazy....
for sticking my nose in here
😱 but nothing I'll duck fast
A great site for this is:
http://www.dofmaster.com/dofjs.html
The one thing that is a "truth" is that DOF is an illusion. By definition, there is only a single plane that is in focus. DOF is purely about the appearance of objects being in focus. There are many quotes at the site above that state this (and it is true based on the "laws" of optics, basic physics).
http://www.dofmaster.com/dof_defined.html
The next thing that you can see on this site is that
1) If the distance to the object is constant
2) If the focal length is constant
3) If the aperture is constant
4) if the film size or sensor size is different
5) Then the DOF will be different
try it on the calculator.
HOWEVER, if sneaker zooming is used to make the image the same size on each of the different film/sensor sizes (ie the distance changes), the DOF will appear to be the same UP TO A CERTAIN point:
http://www.dofmaster.com/dof_imagesize.html
Finally, this is something I believe to be true, but I have nothing firm to back it up:
Print size affects the appearance of focus only if you stand or view from the same distance when looking at different size prints. This is almost the reverse of the distance to the subject effects mentioned above. If you view different size prints from the distances necessary to make each of the images appear the same size, their circle of confusion will be the same and hence their DOF will appear the same.
Ducking and running now
Doug
