Yes, plus artefacts coming from internal reflections like this one (the 35/1.5 delivers some strange ghostings...)
as opposed to
Yes, but it's often just visible as a "haze" in the middle part of the picture, like this one:
I believe this kind of flare is very common with Gaussian wideangle lenses. The Summicron IV-gen 35/2 has exactly the same kind of flare with a bright sky as backlite. For landscapes this can be very annoying. Newer designs like the ASPH.-Summicron 35/2, the ZM-Biogon or UC-Hexanon don't show it (or much less)
Very bad with this kind of flare is the Canon 35/2.8. Opposed to it, the 28/3.5 (designed in the same year 1951 and even looking similar from diagrams) is quite free of it!
To be precise, at f/1.5 sharpness is only present in the very center of the picture with the 35/1.5. But in many cases this is just enough, i.e. when you have a three-dimensional subject and small DOF anyway. Light-loss to the corners can look bad too. You need to think about before using this lens wide open, or to have just good luck. At f/2 it is much better, plus you get nicer bookeh and colors than with the Canon 35/2. From f/2.8 on the Canon 35/1.5 is very strong.
have fun, Frank
