Carl Zeiss photo contest
Brian Sweeney said:
Congratulations on winning the contest!
No help from me on which lens to get, though. I'd go after the 50/1.5 Sonnar. I'm a sucker for Sonnars.
Have fun deciding!
Thank you Brian, I have a final desicion actually 🙂 sonnar for sure 🙂 I don`t think there is any lens even in leica selection that I want more, maybe new cosina 35mm f/1.4 🙂
Also I will need your help, I need to tell them to configure lens either on f1.5 or f2.8 is that right? I remmember some buz going on....
I want minimum missfocus at 1.5, I don`t care what happenes at f/2.8, what kind of optimisation is it? what should I request to zeiss? 🙂
Went outside to test some more adjusted Sonnar's! The older ones. I always shim mine to work best wide-open, Baby... (you have to say that)
Roger Hicks did a review of the new 50/1.5 Sonnar here at RFF.
http://www.rangefinderforum.com/forums/showthread.php?t=51092
I know how to correct the older lenses: I shim them using a through-the-lens viewer, and always set them wide-open. Seems to work. The viewer is from the 1950's, and has a high-power finder. I'm thinking Zeiss has a better way...
Sorry Rob, I though every top 10 photo was getting lens!
Fuwen! I have no clue! I want to shoot at f/1.5 otherwise I use my planar, which one you suggest?
I dun think I am in a good position to advise. I am quite happy with the ZM 50mm Planar. If I were to get a 50mm Sonnar I will probably go for the f2.8 optimised version as I am not a wide open aperture shooter. But what I really want now probably is a silver Zeiss Ikon body.
But since u will be shooting primarily at f1.5 maybe a Sonnar optimsed for f1.5 is good for u?
