conradyiu
closer
Which Contax T you have and recommend ? (in terms of image quality)
fbf said:I loved my T2 and the image quality was superb. However, I think its a little bulky for "pocket size".
nightfly said:I use a Yashica T4 when I need a compact P & S with a good lens. It's cheaper, lighter...
Monte920 said:I second what awilder had said. I also own both T2 and T3. T2 is an excellent camera, but T3 is simply a better camera, no question about that!
1. Image quality: T3 is sharper, more contrasty, and less vignette than T2. You see the differences even on 4X6 prints. You will see a bigger difference if you shoot slides.
2. Built: T3 is smaller, but has a more solid feeling, especially when the lens is out.
3. Convenience: T3 focuses closer (0.4m vs. 0.7m, a huge difference!), can leave the film tip out (a real plus!), can attach a filter (with an adapter), and can stay fixed at the largest f2.8 for sure (T2 can't).
4. You can still manually control the apertures on T3 when using the flash, as long as it is within the flash range. You can't do that on T2.
5. There are occasional focus problems on T2 when aiming at closer object (under 1.0m to its closest 0.7m). T3 is rarely a problem, even down to 0.4 or 0.5m.
6. The only better things on T2 are easier-operating aperture ring on the lens, and a bigger viewfinder.
I have the T3 (Sonnar 35/2.8) and original T (same Sonnar 38/2.8 used in the T2). In terms of image quality, the T3 is better in matters of contrast, sharpness and color saturation. In fact, the S35 is one hell of a lens if you want ultramodern rendition. S35 and S38 vignetting is about equal, with little improvement stopping down. The older S38, however, is extremely attractive on its own terms, and produces a negative with better tonality. In summary, get both!conradyiu said:Which Contax T you have and recommend ? (in terms of image quality)
raid said:Can you find a mint T3 for $185? ==> No
Can you find a mint T2 for $185? ==> Yes
Is the T3 worth the difference in cost?
