jaapv
RFF Sponsoring Member.
This is about the limit of what the M8 can do without getting into PS tricks
Richard Marks said:Well lets see what we can do
Some of the highlights on the right hand side are s bit gone but still detail in the pillars
Shadow detail of the pews a bit better
Windows have appeared in the left side of the image
The catch is always in an accurate comparison and clearly we can only guess if the image would have more highlights with the big gun big bit machines.
Regards
Richard
jaapv said:This is about the limit of what the M8 can do without getting into PS tricks
xihalife said:Thanks... I guess we don't need to compare to big guns, a simple Canon 400D would do the trick. I can tell you we don't need to guess if higher bit depth would save the highlights. I thought about this a little and it's pretty obvious why Leica needs to cut off the highlights. Even though they have 14 or 16 bits of precision, they use a look-up table of 256 values to cover the image.
This means you can have 65536 (if it's 16 bits) different values for light intensity, but only 256 of those can be used in a single image. This actually works pretty well if the values are close to each other. A regular 8-bit image has 256 linear shades of light (from 0.0 to 1.0, or black to white), but the M8 compression is actually able to fine-tune the selection. This obviously results in better-than-8-bit results as long as the compression code is doing a good job. It's not as good as real 14-bit image, but perceptually it can be fine, especially if minimal post-processing is applied.
It *would* be a perfect solution but you simply can't allow any over-exposed pixels (value over 1.0) as that would decrease the quality of the "visible" light. If you allowed 4x over-bright, you might have to use more than half of your 256 values to cover pixels that appear white unless the exposure is changed (a real 14-bit image could be for example 12:2 fixed point value where you have 12 bits of decimal and couple bits for pixels that are up to 4 times brighter than white).
Your photos are beautiful, no question about that. It's just that with M8 you need to watch those highlights (and at higher ISO you need to watch the shadows, too).
Yes- I have some detail left in the highlights in RAW, but I would have to layer and dodge and burn to get it on the screen.rsl said:Very nice, Jaap. In the original, is there still detail in the bright side of the pulpit? It looks a little blown out on my monitor, but the shadow detail is outstanding.
Thanks the lord!jaapv said:Yes- I have some detail left in the highlights in RAW, but I would have to layer and dodge and burn to get it on the screen.
Very impressive. I know where to send my probelm files!sitemistic said:A little playing around in ACR and PS3
footnoteblog said:Jaap, you should check out the Fill Light feature in Lightroom. It's pretty blunt, but works much like HDR (but not like the typical HDR shots).
jaapv said:I don't use LR, don't like it. I use either C1 or ACR, and pp in CS3, ACR has the same features as LR.
I think you will find that quite a lot of Leica RF users have chosen the M8 for the amount of control that the camera affords. Possibly not the main stream of post processing electronic wizardry. The idea is to get the shot. Occasionally minor tweeks here and there are necessary, but personally i would much rather spend the time taking photos than pouring over a PC monitor. Eachto their own of course.footnoteblog said:Hmm. I think Lightroom has a lot more features, but if you don't like don't use it, certainly! 🙂
Anyway, at least try out the Fill Light feature (for shadows).
jaapv said:That is correct, Russel. The only reason, imo, to prefer LR over CS3 is the price.
xihalife said:LR and CS3 are for different use. I catalog my images in LR and if serious editing is needed I send them to CS3. But generally LR has easy slider controls to almost everything I need. It imports RAW and has excellent automatic settings for JPEG conversion. I could think of taking a set of 50 RAW's and making JPEG's out of them using CS3... (surely if you don't post photos on the web you might not care about it).
