Paul Kay
I have taken many HDR images on my Canons taking multiple exposures and using them to create high bit depth files which are then remapped and output as 8-bit files. As has been stated, the results can be spectacularly good.
However I also use the same software (Tone Mapping from Photomatix) on Leica M8 files which I process as '16-bit' conversions from Raw. Whilst I fully accept that theses files are not true 16-bit files and that theoretically at least I must be losing information, in PRACTICE the M8 files and Tone Mapping work extremely well together and the results can be, although different from true HDR generated images, extremely effective.
Attached is an example taken on an M8 with 24mm Elmarit and IR filter at 160ISO (ie very 'straight').
This is not 'magic' but does work AND I cannot achieve the same results direct from a 12-bit Canon file, which is because of DIFFERENCES in the files. As Richard says, if you haven't actually sat down with M8 files, its difficult to appreciate their strengths (and weaknesses) but this doesn't mean that they don't exist and are merely a figment of Leica afficianado's hyped imaginations!
