squirrel$$$bandit
I'm thinking of adding the 90mm to my G1 setup. Any issues with this combination? Focusing/metering/etc?
Cron
I have a 2,8/90 in use together now with a G2, formerly with a G1. Never had any problems with focussing, meters in both cameras work perfect with this lens (and I normally use slide film). G1 focusses not so quick like the G2 with this lens, but very accurate even in low light situations. So I can recommand this combo.
squirrel$$$bandit
Terrific! It's quite a surprise how affordable this lens is.
awilder
Alan Wilder
I had less luck with the 90 on my G1 although when focus is spot on with the 90 Sonnar, I tested it to be as sharp or sharper the the current 90/2.8 Elmarit-M, the sharpest 90/2.8 in current production. I sent my G1 back three times to Kyrocea for calibration before they got it close but it's was never quite as accurate as the 90/2.8 Elmarit-M on my M camera. I've read of other people having focusing issues with the G1 and the 90 on their user group forum but I understand the G2 is much better at focusing the 90.
joachim
Convicted Ektachome user
no issues
no issues
I use it for years on my G1. No issues concerning focus accuracy with reasonably static subjects. Though the camera is not up to track a walker moving towards the camera in AF-C mode, but neither is any manual focusing rangefinder camera since it lacks the AF
You might want to check that you body is reasonably aligned. I tried a few bodies when buying mine new in 2001. Many gave different readings for subjects which were not orthogonal in the rangefinder, that is cutting the in finder brakets, like
[ / ] or [ \ ]
my body gives the same distance reading in either case (to the cm). I could well imagine that bodies giving different readings have problems getting the 90 correct.
no issues
[ / ] or [ \ ]
squirrel$$$bandit
Well, I just bought one from KEH, with caps and case, EX+ condition, for $119. Wow! On eBay they go for twice that. Will report.
foto_fool
I have the 90mm Sonnar as part of my G1 kit. I have never had any focus or metering problems with it. Though there is enough echatter about issues with this lens on the G1 to be aware of.
Even though I don't have these problems with my kit I wonder if, when there is a problem, it is always with the body. Might the particular lens not be the source of the trouble?
joachim
I just remembered one more thing. The very first batch(es?) of G1 had faulty look-up tables for the 90. This got fixed in later versions. (Reported e.g. in Amateur Photographer.) The look-up tables are needed to translate measured distance into rotations of the drive shaft. As far as I know, all green stickered bodies have this fix. I do not know about the silver stickered one. All G2 should be fine as well.
As I wrote earlier, I personally do not have any issues.
squirrel$$$bandit
Good, I've got the green sticker...
squirrel$$$bandit
Well, took the 90mm out for a shoot yesterday, and so far I am having no focusing problems at all. It works as smoothly as the 28mm, which is to say pretty smoothly. I'll post images once I finish the roll (Neopan 1600).
KEH, as usual, understated the excellence of its condition. It looks like new to me.
