Test - ignore
Another try
Another try
81606673
hmm, does the link you have end in ".jpg" ?
If not, you might be linking to the page and not the image. To post up a photo you need a direct link to the image itself, not he page its contained in.
It can be pretty confusing at first.
For example, the actual link for the image contained in that page you tried to put up on your first post is: http://i.pbase.com/g6/99/33899/2/81606673.Dwrq1lwE.jpg
What you need to to do is put the
Were did that tag come from? it is significantly different from the original http://www.pbase.com/hlockwood/image/81606673.
It seems you guys refuse to ignore someone with a problem. Thanks much for your patience.
Harry
You can usually right click on the image to see its properties (on a PC). The image link will be in there. It'll be the one ending in ".jpg" like i mentionmed above.
good man 🙂
Ok go to the pbase page that shows the image you want to post.
Now see the black area around the image? put your cursor on that area.
Then hold down the control key and click you mouse and hold, see wehre it says "view source"? choose that and a wndow will pop open that shows you the html of that page.
Now scoll down that page until you see this(about 2/3 down the page):
src="http://i.pbase.com/g6/99/33899/2/81606673.Dwrq1lwE.jpg"
copy only this - http://i.pbase.com/g6/99/33899/2/81606673.Dwrq1lwE.jpg
Copy it by first selecting it by clicking,holding and dragging your mouse over it until it is all highlighted. When its highlighted copy it by hitting your apple key and the letter C at the same time. Then go to RFF and click that box you did the first time you tried and paste it into that box. Should work.
good man 🙂
OK, got it. I'll try another:
